Hi there, thanks for having me on the forum. I just bought a K2 set of a friend. I was reading the forum and stumbled onto the power drain discussion. As the converter module I have is an old one (no led) I'de like to get the updated one. Will Innovv still swap these? And if I were to fit the K2 on a Ezcan....would that help combat the power drain. I've seen other solutions but non mentioning the Ezcan.
Hi
Just ask them at tech@innovv.com
I don't know what options Ezcan offers. Of course you could connect the red/black wires to a port on the Ezcan. When ignition is switched off, this will also cut power to the K2 and will prevent any power drain. But if you cut of power to the K2 before is finished its shutdown, the current videos will get corrupted.
So you need to make sure that first the power is cut on the yellow wire. 10 sec after that, the K2 will start to shut down, which takes another 10 sec. So you would need two ports for the K2
One port for the yellow wire, which cuts power when ignition is turned off
One port for the red wire, which cuts off power 20 sec after the first port.
Then you are on the save site.
Hello, apologize for any inconvenience that has caused first. Please kindly contact the seller to directly change the converter module. May you have any other question, please feel free to contact us.
Thanks you Innovv for the reply. But as I bought it second hand I can't bother the seller with it. Can I not just swap it via the Dutch importer Zodiac?
@leroi50 Sorry to hear that. In this case, please kindly contact the Dutch importer to further check this.
