Ok, not used the bike for a week, went to go out today and the DVR won’t boot at all.
The blue light on the converter lights up but the DVR just does not power up.
I have tried connecting it to a USB lead, pressed the button still nothing.
I am going to look at the SD card to see when it last recorded, but that doesn’t help me now.
Any ideas?
To be honest over the Christmas period, I have not done anything further. I did double check all connections when I realised the issue, and disconnected the DVR from the bike, where I used numerous USB leads into a power point, the same as when I first got it, I even used the same one, amongst others, nothing seemed to get the DVR to even fire up.
I have checked all connections and all seem good. The yellow cable is soldered to the rear light connector. I have tried different usb leads. Still no power to the DVR?
I am having the same problem, blue light on converter comes on and pressed reset but nothing happens. I have also tried the same with usb power supply?
Please find the reset button beside the mini USB port and press it, then restart the motorcycle and try to connect.
