After fully instalment of the system i can't get it to work anymore? I've tested it on multiple ways and times before i put it all on my motor (also tested on the battere and a switch from ignition).
Now the converter doesn't seem the work properly(?) since it gets 12 volt after the fuse, but as seen in the vid; the blue indicator only lights up for a second when i put in the fuse?!
If anyone could help me out that'd be great!
Yellow wire is not attached. Check with it connected and see what happens. Yellow wire appears to be resting on plastic tubing or is it the metal frame of bike? (short)
Tried, didnt work.
Thanks for your quick reply, your answer got me thinking.. it was something with the yellow wire indeed.. the connection was poor
Great!
Normally there is a 10 second delay when the converter is turned on, and the blue light doesn't come on 10 seconds after the fuse is put in?
How about using the USB power supply?
Connect a USB cable to the DVR's Tiny USB port, and use an external power source at the other end to see if the DVR can be turned on.
