anything that will fit the latest liquid cooled BMW twins with the can bus system. apparently fitting a C% to mine will invalidate the warranty as it is not BMW approved.
Yes installing an HexEzcan should not invalidate warranty since there is not splicing/cutting required.
https://hexezcan.com
https://hexezcan.com/installation/
Your warranty is not voided because you do not cut, or tap into, any wires. (https://hexezcan.com/faq/)
Have moved the discussion to K2 category.
You can refer below discussion to see the connection with CanBus with eZcan, that will be helpful.
https://www.innovv.com/forum/innovv-k2/hex-ezcan-and-k2
