Lost my 32g card
put my 256 (Sandisk A1) card in..
nothing works now..
first insert it ask to format card said ok, next it said error on card. could not connect via WiFi from app, reset the unit and still not connecting .. pulled out the card, put in PC at work, and it’s formatted in exfat?? (not sure what the difference is but had no option for fat32)
I reinstalled card and still nothing..
Im not technically good with this stuff but .. I didn’t do a thing but change cards..
do I need to get a smaller card even tho it’s stated to work with 256? only had unit for a few weeks.
That your card got formatted in ExFat indicates that your K2 is running V0.5x, as these firmwares are the only one using ExFat. But they also have a bug regarding ExFat and 256GB cards. So I suggest to update to the latest V0.70.
Before doing the update, you need to format you sd card on your pc in Fat32. Otherwise the update will not work. Or you can use a smaller card (32gb or smaller), format it within the K2 and use this card for the update.
