Hello,
I want parking mode activated when I park, but don't want to turn it on and off each time.
If I leave it on, does the DVR change to normal loop recording mode when the ignition switch is on?
Or do I have to manually turn it on and off each time to record normally while riding?
Thanks!
Parking Mode has nothing to do with loop recording.
Parking Mode simply means, that when the K2 is switched off and it registers a shock, it will start up, records for 20 sec and go back to sleep. If there is another shock, it will wake up again...and so on.
Yes.
You can leave the parking mode on.
Even though it seems that the K2 is switched off, the parking mode remains active.
The K2 switches on when the ignition is switched on, the K2 switches on in loop recording mode.
