Hello, I'm pretty new to the Innovv K2, just did a few rides with it.
After having used the camera for a few rides I formatted the SD-card with the Innovv K2, enabled Parking Mode, changed to MP4, and noticed strange behavior the next two rides.
After the first loop I'm missing a few seconds of video footage, and from that point on the video is saved upside down.
This is for both front and rear cam and for both rides. I copied the .MP4 files off the SD card directly. App also shows upside down video footage.
Any clues?
I'll try to reset the K2, format the SD and see if this behavior is persistent.
Last frame of 1st loop:
First frame of 2nd loop:
Furthermore my firmware shows V.68, which seems newer than what I can find online.
You need to rotate the camera that's upside down 180 degrees in the mount.
My cameras have the label on top, did work correct the fist few rides.
Why should the video flip vertically (for both cams) after 5 min drive? And then keep that way until starting a new ride?
(you can see from the timestamp that these are a few seconds apart, just after the first loop)
I'm not sure what to tell you then. Perhaps contact Rock at Innovv. It might be worth the effort to rotate it for test purposes..
The firmware version on your K2 is a little bit strange.
K2.20200415.V0.68.LensR ??
V.68:
As far as I remember, there is no official V0.68. Do you use my modified V0.67 firmware? As this is the only version from which I know that it calls itself "V0.68".
LensR:
I have never seen this description within a firmware version.
I would suggest, that you at first flash the latest firmware from Innovv.
This is the firmware the device was shipped with. I did not upgrade/downgrade (do not know if this makes sense to do...). I contacted Rock for help...
@Tjalling Koopmans
Very strange. But I just see at the Innovv page that there is a new V0.70 firmware.
It is commented with "Add the function of turning the lens flip 180°".
I suppose that there was an unreleased V0.68, which has been installed on your K2 by Innovv or the reseller.
The V0.67 has a date of 2020.04.10
The latest V0.70 has a date of 2020.05.13 (website says 20200514, but in the firmware file it is 20200513).
The V0.68 on your K2 has a date of 2020.04.15. Means 5 days later than the V0.67.
In other words...your K2 runs a firmware that has never been officially released by Innovv. At least according to their webpage.
Wild Speculation on
Maybe the V0.68 was to test the new lens flip function. And also the reason why Innovv did not released the fixed V0.67 as V0.68. Simply because internally there already was a V0.68. But for some reasons (still some bugs??), it was never released.
Wild Speculation off
Anway...I would still suggest to install the latest firmware.
Update to this symptom.
I updated my firmware to V70, did a reset and formatted the SD.
Still my camera footage was upside down.
Please note my camera logo’s are on top, and my camera footage was correct after initial installation and configuration during the first week.
As I tried to correct this by flip upside down in the software/app (as pointed by Cai), this resulted in a upright video footage BUT mirrored left-right. Like I’m driving on the wrong side of the road.
Flip upside down is therefor not useful if you cannot mirror it left-right AS WELL.
Therefor I rotated my cams mechanically 180 degrees, logo on bottom. This has the desired result, but is very unsatisfying. Could well be my footage flips again to it's original setting later ...
Can anyone explain this behaviour?
I had the same issue, but only after updating the firmware with a (unknowingly) unreleased version by some hack! The version I installed was K2.20200513.V0.70 that screwed up my system. Thanks alot jerk!
Hello Steve, apologize for any inconvenience that has caused first. Please kindly uninstall the INNOVV K2 App now and download the latest App named INNOVV from App store.
