*Hi, we are having a eight-day break from September 28 to October 5, and may not be able to ship out the package and reply to your email on time. Thank you for your kind support.
The blinking red led indicates that the DRV hangs at some point in the boot process. But as the DVR does not write some kind of logs, there is no way for you to see, what's going on.
Strage thing is, that without the cams, the DVR seems to start normal till the point where it tries to initialize the cameras. So what you can try is, test both cams by only connecting them to the front port. Maybe one cam (the front cam) is broken and that confuses the DVR. If this does not help, I am afraid we are at a dead end here.
The behaviour shown in your video is normal. As there are no cameras connected, the DVR constantly restarts in the attempts to find at least the front cam.
Please connect the cameras and try (and post the video) again.
I guess there is no more warranty, right?
no wifi, led is lid up but wifi not working device is also not recording.
Same behaviour is with the cameras plugged in. No WIFI connection available
Several people looked at it, device is been able to connect from wifi and wired. see the video
I live in the north of the Netherlands (Drenthe), if this is near you I would like to take a look at the problem. Two see more than one ;-)
Ik woon in noord Nederland (Drenthe), mocht dit bij jullie in de buurt zijn wil ik wel eens mee kijken naar het probleem. Twee zien meer dan één ;-)
Could you post a video of the led when powering up the DVR?
2 Years old, its the Dutch gramatical Checker,🥴 i'll tried external power, new update, it's dead, led are lit but no connection.
Can you power it by usb? Maybe its the power module, which got broken.
...its been just 2 jeans old number 106??
Ehh...what?
