12v switch feed was taken from the right hand front accessory outlet for the power unit, red and black direct to battery. note the accessory outlet has a delay shut off built in (about 1 min) so the unit will stay active after ignition is switch off, if you are running an accessory of the outlet it remains live with a buzzer warning. i ran the wires down the right hand side of the fuel tank taping /cable ties as required the front camera is spot on no vibration (when fitting not double lip in plastic) etc the rear camera is ok but movement from the box/ rack makes the video a bit jumpy probably with weight in the box this will be reduced?
Very nice and neat install.
Not so clear your question below.
Hi Liu thanks for comment i remove the petrol tank cover /trim to expose the tank I then taped the wire to the side of the tank then refit trim/cover hope it helps
Thank you for expiation.
Pined the threat on top for good reference.
Did you drill straight through the rear top box carrier to mount the rear camera?
Hi John yes I did but I had issues with vibration as it turned out I had major issues with the bike as well so BMW gave me another one, I removed the number plate and made a bracket to fit the camera on the top /side of the number plate this works much better, I positioned the GPS recieved on the underside of the fairing it works fine. I also used some heat shrink tubing and a watch glass to cover the front lence works a treat
Cheers
Mick
Many thanks Mick.... Ive done the from as youve done.... I will follow suit for the back :)
