So I have patch 64 installed and the WiFi light isn't flashing Blue. I have performed a reset but nothing appears to have reset ie the renamed device doesn't revert to the original name etc.
I can still record and view files with the Android phone over the K2's WiFi.
Is the until buggered or just the light.
Yes, the only way to get the WiFi name back to the original is to refresh the firmware.
Can't you go back to the original WiFi name after you refreshed the firmware?
One of the new features in version 0.64 is the ability to turn off WiFi at regular intervals. If you select 5 minutes later, it will always turn off WiFi after 5 minutes unless you change the time or turn off the feature yourself.
If the wifi name did not reset to the default name, I would guess the update was not successfull and you are still on the firmware that was installed before.
Did you check the firmware version after the update?
