so I bought my camera system September 2019 which is after innovv had Released their solution to the battery drain. All wires are connected to the power converter per innovv instruction. I have turned off the park functions, but when the ignition is off, and camera of it is still pulling around 47mA causing the battery to drop below voltage and not start. I have emailed innovvv, and gotten the same generic response which is install Instructions. I have had my company plus Harley Davidson check l, and recheck, and recheck again the wiring It is connected correctly. anybody else had this issue with camera purchased in 2019? this is frustrating since this camera is extremely expensive.
Search
Where did you buy your K2? If not directly from Innovv, chances are that you got one from stock, including the old converter. The current converter has a blue LED to show the status.
If you converter does not have a blue LED, I would guess you got the old one. Especially because of the 47mA, as this is the exact current my (old) converter takes. But I resolved this issue by using a timed relay.
You should contact your reseller for a replacement of the old converter. If he cannot help, you can contact Innov for a replacement at tech@innovv.com
I'm using a timed relay as well as an extra preventive measure with my K2, also on an H-D.
Hey Bryan, we've explained to you by email how the new converter with blue work lights works, so if you need any additional help, just reply to our email.
