Hello and good morning, I have an INOV K2 fitted to my 2019 R1250 GSA HP , it’s been on the bike about three months , but I’ve noticed the bikes battery going flat and I wasn’t sure what gnaw cause was until
a few days ago , I took it to my local bmw garage and they have diagnosed the problem to be my camera system, apparently it’s taking about 1.5 amps from the battery when the ignition is off ! has anyone else had any similar problems?
I have not seen the drain that high on our bikes. it runs @ 0.63A running, with occasional jumps to @ 1.2A I am guessing when it is writting. When the ignition is off, and the unit turns off, it draws @0.3A. Is the unit set to stop recording 5 or 10 minutes after the ignition is turned off? We have ours powered through a Neutrino Black Box, which shuts off all accessories if battery voltage drops below a set level.
good.
