I have read on this forum that the battery on the motorcycle drains in a week even when turned off. Do I need to switch off god and park mode to stop. Artery drain?
Does using the PDM 60 help this issue. If so as the pdm 60 is slready switched and only power on with ignition where would the yellow wire go from K2 power converter?
The K2 has smart converter to avoid battery drain.
The converter can detect the voltage from motorcycle battery.
1. when the voltage is more than 12.7V, the power consumption is 30mA when camera system stands by.
2. when the voltage drops to below 12.7 V, the power consumption is 8mA when camera system stands by. with 8mA power consumption, the motorcycle battery takes 2 weeks to drop voltage from 12.7 to 12.0.
If you do not ride motorcycle often, the better to switch off the park mode.
PDM60 dose not help on this.
