Something i discovered that probably should be obvious but i missed it. When setting the Loop to OFF to allow 15min Clips to be recorded then this actually disables the Loop record function so that it will not erase older files but will only record until your SD card is full.
Not sure if anyone else has this set but you will soon run out of space on the SD card with this setting.
You are right, that is the difference between Loop recording and non-loop recording.
Click settings, You can find loop time, Click it and there are options.
Rock
Ive noticed that only some of the recordings are 15mins long the others are 3.
How do I set the time for recording ?
15 minutes is the longest time for the video clip.
The reason is 20 minutes will make the video clip a very large data, it is not easy to review on App and download it from SD card to phone or PC.
