Jun 5
512gb Micro SD Support Please?
3 comments
Is it possible to add support please for micro sd cards greater than 256gb? Support for 512gb or even the latest 1Tb cards would be amazing.
I'm about to head off on a trip through the Alps for a few days and would be nice to keep as much footage as possible so I can edit it down, rather than having to keep swapping memory cards.
Not sure whether the 256gb is a technical limitation, or arbitrary choice?
Thanks
Jun 12
Have not tested 512GB SD card so far but be sure, 256GB is supported.
But do not recommend to use such largest expensive SD card.
The K2 has two cameras which is writing data to SD card same time, it requires high writing speed. U3 or above is required.
If such largest SD card is not capable for that, money will lose.
You can refer below link,
https://www.bhphotovideo.com/explora/computers/buying-guide/the-fastest-memory-cards-money-can-buy
https://www.sdcard.org/developers/overview/speed_class/
I have a high spec 512gb card I tested , bit it is not currently recognise by the K2 unit.
Jun 15
Thank you for update.
New Posts
  • @Michael Williams asked in in another thread where we are all from. I am interested in this, too. But as we should not spam a thread about a technical problem with off-topic posting, I decided that is would be better to create a separate thread for this. So here it is and everybody is invited to tell us where he/she is from and show us how international this forum is. I am located in a small city beside Duesseldorf, Germany, and riding a Tiger 1200 XRT.
  • Had the K2 for 5 days now. Overall its pretty good. I have a few issues that I need to look into. 1 - The lens seems to black out in the bottom (say 4 and 8 O'Clock) A bit like the lens has Glaucoma... 2 - I start my bike, put helmet, gloves on, ride off, but recording doesn't start until I am a few miles away, has to be at least 5 minutes after setting off, and maybe 6 minutes after starting the bike. An I supposed to wais 6 minutes before setting off? 3 - I have to do something with how I transfer the files, WiFi just doesn't cut it. My bike (R1250GS Adventure) automatically powers off after X minutes, not sure exactly how many, to preserve the battery, the WiFi hasn't managed to transfer a 3 minute file before the bike powers off. I cant view from the bike, stream, as it doesn't stream, it just jitters from frame to frame. I have an iPhone XS Max if that makes any difference. So far I have not been able to download or view any recording, only when setting up on live view. On the plus side, it only took 30 minutes to set up on the bike, only having to remove the tank panel. Does anyone have any thoughts on my three issues?
  • w-tbird
  • w-facebook
  • w-googleplus
