Hi, I've been out for 2 - 1-2 hours rides now to test the Innovv K2. Here are 3 issues that comes up so far and if anyone can help me please do.
1 - After about 30 minutes of riding my gps fails to work, the K2 continues to record but the speedometer freezes at a certain speed and never changes until I turn everything off.
2 - In the SD card it creates 2 folders - Video and Park, I do not have Park mode activated. It puts files in both folders.
3 - When I turn off my bike, usually it stays on for 10 seconds then turns off, but the LED wifi, camera and gps stays steady on, until I turn the ignition back on then the LED turns off,
Anything to help would be appreciated.
Where do you mount the GPS? It needs to explore to the sky. GPS is waterproof.
Park mode folder combine files generated by G-sensor and Parking mode.
As you do not enable Park mode, so those files were generated by G-sensor while you ride on road, the vibration/Bump.
Where did you connect the Yellow wire from the converter? It should be the switched power source.
Base on your issue, can you change the yellow wire to other switched power source?
Keep me updated after your further checking.
