There is literally nowhere to mount the front camera on this model. I do not want to resort to drilling holes or using hose clamps on the slotted base. Also, the slotted base does not allow enough clearance for an inverted bolt from bottom up, if using the 3M adhesive option.
Does anyone have the K2 mounted on a Concours 14?
I just searched for the model on Google, I don't know the model itself. Is it a Kawasaki?
But if I see it correctly on the images found, there are a few screws under the headlight?
Maybe you can put a longer screw here where you attach the K2?
Cheers mate! Yeah, I thought of that but they are too recessed to give peripheral view. I ended up using a GoPro Ram/included L bracket/included rubber donut(to fill empty GoPro slot) mount on the handlebar. It is kind of obvious but it does the job.
Okay, I couldn't see that from the pictures on the internet.
But you did eventually find a solution.
Is there no forum for the '13 Concours 14 where they can help you?
Thanks again.
