So I have to say I am for the most part happy with what I have in the K1.
The mounting hardware provided is lacking. It would be nice to have a bracket that mounts to either side of the camera.
I have it mounting on my Vstrum and could not use any of the supplied brackets.
I wish the light for the record button was much brighter and the cable thicker.
I can only see the light in the evening or when in shadow.
Two times now I have had the Recording stop loop happen.
I have also noticed gaps in the recording.
Recording setting if for 5 minutes. Running a 128gig class 10 card that has been formatted from the DVR.
I have a K1 fitted to my Triumph Sprint for some time. It has been extremely troublesome. I have tried four SD cards, three voltage control units, single ferrite cores, double ferrite cores (pass through twice), electrical connections made from various points.
At the moment I am using a 128 Class 10 SD card bought from a national retail company, my cables are looped twice through ferrite cores and power is taken by latest voltage control unit from INNOVV. Still having major troubles. It is rare to complete a journey trouble free.
Recordings usually have failed by the time I return home. Sometimes DVR just freezes, other times continually saying 'recording started recording stopped' until I press reset button. Any recorded segments are all of different lengths with gaps inbetween. Othertimes my recordings can change colour to a purple haze!
It is obviously unable to work due to the unshielded cables which continually pick up interference from Triumphs electronics.
Does anyone know where to obtain shielded cables? INNOVV say their cables are tested!!!
I agree with Jeff, the remote record light button is useless. I have to stop and place my hand over it to see if it is still recording or stopped! Usually it has stopped and pressing the button does nothing until I press the reset on the DVR, after removing the seat!!
I paid a high price for something I cannot rely on. I have installed two cheap bike cameras, front and back, as a back up. At least these cheap bike cameras are reliable.
Hi Jeff,
We have been thinking about to supply the screws for mount to bike side, but checked with riders everyone is using the different screws.
And you can see from below sharing, more than 1,000 photos, people always have their own way to mount on different bikes.
http://www.flicker.com/innovv
Have noticed the LED light issue on button, have tried to make the white plastic part to be transparent, it does not good.
You can set the video clip to be 1 minute and see if any issue.
Hi JDC,
Can you please remove front camera and only keep rear camera to see if has such issue?
and test with only front camera.
So we can see where the interference coming from.
Changed setting and not real improvement.
Ever since adding a Car ID I no longer get any G sensor readings in the viewer.
Hi Jeff, What settings have you changed?
Car ID does not affect G-sensor.
Have you tried only one camera connected?
