Hi all,
on my K1 installed about 2/3 months ago on my burgman650, sometimes it happens the following: I turn on engine key, power supply turns ON K1, K1 says "Record started", and red led on the button is ON, then when I push the brake lever to start the engine, red led goes OFF, and it stops...
This happens sometimes, and I cannot say why...does anyone has same trouble and got the reason?!
thanks in advance
Better late reply than never... Think about this....
When your turn on power to the system (bike) the K1 DVR boots properly, but when you crank your bike (start the engine) your starter pulls a large enough amp/current draw which reduces power to the accessory devices including the K1 DVR , not enough to completely reset the DVR (sometimes does, sometimes does not) but enough to corrupt the DVR operating system and preventing it from operating correctly till the K1 DVR is reset...Wouldn't happen every time. just depending on the power draw..(cause by conditions like low battery charge, temperature, rain, snow, thick oil, high compression ect..)....
Might explain some startup problems on the other systems (C5,K2) ...
