Hi Rock , as per my post in the K2 forum, the K1 has been brilliant up to now, but following that post, I think I spoke to soon !! last night I went to download the footage but the unit is completely dead, won't turn on , nothing, the charging light on the side is on (faint white light) but nothing happening. I tried a reset, plugged it back into the bike, nothing, completely dead, any ideas what is wrong?
thanks
Hi Chris,
According to your description, we think is that something is wrong with the K1 battery.
You can search Amazon for the same battery for replacement, and the keyword is "GoPro hero 3 battery".
These two batteries are the same, remember to read the specifications carefully before buying.
Let's see if your K1 can work properly after replacing the new battery.
Chris,
Have you tried removing the battery completely and turning the power on with a power cord connected?
Chris, you can try the way which suggested by @Nate, take out the battery and then connect the K1 system directly to your motorcycle.
it's wrong model! Why INNOVV don't support k1 now? 1,5 weeks ago front camera get water inside after rainy weather and +4 Celsius. Why?? How fix that?
In that weather k1 get boot loops after starting and DON'T WORK WITHOUT BATTERY. WHY? WHY I LOST 280 USD after using cameras set in 2,5 seasons (3 year)? WHY INNOVV DONT SELL BATTERY FOR K1?
Thanks, INNOVV. I get died battery 1,5 weeks ago, and traffic accident 2 days ago. And I could not prove my innocence due to the fact that innovv k1 did not work and I did not convince the road employee that I had been cut across and because of which I changed the trajectory of my movement and damaged an innocent car. As a result, your camera is an expensive useless toy with not worked out software, the lack of a normal diverse mount, and most importantly the lack of technical support several years after release and spare parts. Why did I give money, scammers? NOW i found right model of battery pack. Guys, You can buy battery pack from GoPro
for: HD Helmet Hero, HD Hero, HD Hero 2, HD Hero 960, HD Hero Naked, HD Motorsports Hero, HD Surf Hero
part numbers are: ABPAK-001, AHDBT-001, AHDBT-002
INNOVV? NEVER AGAIN!
I agree with you, this camera system is not that old and it should be supported. I will not buy another Innovv system again because it feels like a rushed product. I no longer ride a motorcycle but I purchased the K1 vehicle version, the K2 version (what ever they are calling it now) is only for a motorcycle. The K1 hasn't worked properly in years and I cannot count on it to work correctly when I have it turned on.
It boots and reboots constantly with no further firmware updates to address the issues everyone else is having. I have to listen to "ding ding ding" for the first 10 minutes of my drive, if it boots correctly the first time, I get to listen to "Recording stopped, ding ding ding, recording started" repeatedly... As I said before, it literally rebooted 12 times in a 4 mile drive. I'm just done with this system, I'm saving for something else and as soon as I find something good enough I will replace this system and throw it away.
Sorry Innovv, you guys failed this time.
@zerbino I'm sorry again..
As for the battery transportation, DHL and other logistics companies have clear terms and restrictions.
We have no way to send this battery out, and once sent it will be stopped and returned.
Therefore, we generally recommend customers to buy the same type of battery from Amazon.
I hope the new battery will make your K1 work properly again.
Thank you for listing the above general battery models.
@innovv So if you cannot ship the battery because of the restrictions set by the carriers, how are you able to ship the battery with each new system you sell?
And like a cherry on a cake
