Hi, I have the Inovv K1 installed a few weeks ago on my motorbike but everytime I look at the files, They are all invalid.
I am using the Samsung Evo Ultra Micro SD card SDxc 128 gb CLASS 10.
Please help.
firmware version is: K1S_V5-R266/170516 0HW_V5
Have you tried formatting the card from the unit itself? It may help to deal with the issue
You also can try other SD card.
Thks Rock. I have tried, Samsung EVO, Kingston and Sandisk. All same invalid files. Really frustrating. Innovv haven't reply yet.
The camera system had been tested 24 hours without issue before shipping. So let's see what is wrong there.
It is simple, you can do below check,
Turn ignition on (Engine stop), let camera system keep recording for 30 minutes, then you can check if the video clips are invalid.
If recording clips are OK, the issue should was caused by other reason.
If recording clip are invalid, SD card may have problem.
Keep me updated after check.
Hi Rock, I tried the128GB Samsung Evo SD Card and 32 GB SD Card. Both worked when the bike is not running. I too the bike for a ride and when I come back, all files on the128Gb were invalid but all good on the 32GB card. What is your opininon on this?
On the 128Card, i kept geting recording start, recording stop but not when i'm using the 32GB Card.
You can format 128GB SD card in DVR and see if the problme can be gone.
Where did you purchase 128GB SD card?
I did format in the bar and format ok. As card bought from computer shop. Tested again. No problem with 32 Gb. Invalid with 128gb.
For sure the K1 camera system supports 128 GB SD card, and two people even were happy to told me the K1 camera system work with 256GB.
I have a 128GB Samsung Evo in mine, and it's working without problems (from what I can tell)
So is there something wrong with my dvr? This is my 3rd dash cam for my bike. Had Vimel on my other 2 bikes and no problem.
My friend got broken files when main unit has been overheating. He had broken files and pauses in recordings. After fix that - problem disappeared.
I don't have broken files, just all invalid files on the 128GB card. Tried 3 times. Took the bike for a ride, came back, and all files invalid.........EVERYTIME!!!! Brand New, bought 2 months ago and never work.
Any suggestion on type of micro sd card?
louis.loong, my friend changed card too. As for me i use "no name" (for me) micro sd card LD 128GB XC1 without any problems.
Check MicroSD card with h2testw. Try to format card with HP USB Disk Storage Format Tool v2.2.3 or Rufus.
