Aug 11, 2017
Help with additional setting with latest firmware
2 comments
I don't recall these setting being there or didn't notice them until I completed the upgrade and cannot find anything about them in the manual. Any help would be appreciated.
Down the settings menu right below Screensaver there are the following three new settings.
1. Driver Fatigue- Setting are 1H, 2H, 3H or Off.
2. Car Lamp Open- setting are On or Off
3. EDOG Beep- setting are On or Off
Thanks in advance
Aug 13, 2017
Hi Rich,
That is to remind rider to take a rest after 1 hour or 2, even 3 hours riding.
That is to reminder the lamp if On or off
That is to switched on/off remind the sounds from Edog.
Edog is to work with the data of local cameras on high way, it can reminder when ride close the camera on the high way.
Since DVR usually set up underseat, so do not recommend to enable those features.
Regards,
Rock
New Posts
  • After receiving all possible failures from this product, a logical question arose. - So how to buy spare parts for INNOVV K1 from you (manufacturer)? After buying the battery, it turned out that one of the cameras (rear, but installed in front due to the length of the wire) also came out of standing. - How and how much does your new camera cost instead of a defective one? - Where, how and at what price to buy safety glasses for cameras? - Where, how and at what price to buy a new power supply for the camera, because the old power supply does not hold stable voltage and current, as well as poor contact at the USB A female connector due to flat tracks? Remind everyone that You can buy battery pack from GoPro for: HD Helmet Hero, HD Hero, HD Hero 2, HD Hero 960, HD Hero Naked, HD Motorsports Hero, HD Surf Hero part numbers are: ABPAK-001, AHDBT-001, AHDBT-002
  • Hi Rock , as per my post in the K2 forum, the K1 has been brilliant up to now, but following that post, I think I spoke to soon !! last night I went to download the footage but the unit is completely dead, won't turn on , nothing, the charging light on the side is on (faint white light) but nothing happening. I tried a reset, plugged it back into the bike, nothing, completely dead, any ideas what is wrong? thanks
  • So I noticed that in most cases with me the Recording stopped failure happens when I have a drop in batter voltage. Was thinking. What if an inline batter was put in place between the power source and the DVR. Think on of the USB battery packs. Now you would need one that started charging and recharging automatically but think this could solver the problem. The battery pack would simply act as a UPS. Something the onboard battery should already be doing. Also has anyone else though of installing a heat sink on the DVR or even the battery?
  • w-tbird
  • w-facebook
  • w-googleplus
