Hello.
Firstly i want to say, that device very well, but not perfect. 1st - it's hot device. That give us problem with overheating and freezes on recordings with 1-2-3-5 minutes pauses. But this can be easily corrected by the correct installation (By the way, my friend was forced to attach the radiator and fan from the battery side) on NC700 in the luggage compartment on the battery side. And the second is bad, I would even say the disgusting quality of video recording, and hence the firmware. It is so unacceptable that it was necessary to search for the firmware of the "clones" and install them. That is also far from solving the problem. Because of this, you can not, for example, roll back the firmware (install an older version of the firmware), and the quality of the firmware leaves much to be desired. At this moment I, as a Russian user, use the firmware of the clone Inspector Scirocco. They at least modify their firmware. In general, the approach of INNOVV to support its top device in the software plan has upset me.
What does the manufacturer think about this? Is it possible to create a cooling kit?
I understand all, even that c5 have only one camera, and Amba power given to one camera)
I understand your ambitions too. It's good ambitions!
But now we have what we have. Please make some improvements to FW and ability to manual update/downgrade/rewrite FW.
I am glad that we can talk together about products, that is one of our core advantage than others.
Please trust us that we have ambition to make the best motorcycle camera system, and you can see the improvement made on new released C5.
i understand all, but.. lets see some pictures.
They shout that bitrate is clearly not enough. And this is always seen.
And for that matter, Ambarella has other chips and it was possible to put just two chips. In general, the main is desire of creators, and for 1 chip additional people would overpay $ 60. I'm not saying that Innovv has a poor quality of goods, but it's not enough to identify numbers in many cases. Simply at the moment it turns out that k1 is used for fixing the action, rather than fixing data about the car's numbers.
original https://www.solidfiles.com/v/KqXrx7WynVRND
When talking about the video quantity, we may need to consider the structure of the camera system.
The K1 has two channels, and both channels have been wired, that generates the limition.
1. the chipset only can support 1080p 30fps for both channels.
2. the chipset has limition to deal with the data transferred from wired lenses. (If we set even higher bit rate, the chip set can not handle.)
The K1 has same chip set which Gopro used.
You can see we do not make cheap product, and believe you agree we had taken great effort to take up such challenges.
Checked the video, from below the screen shoots, it is good, that you can see the plate number in such distance from the video.
At the moment I do not need anything. I'm somewhat upset with the video quality of such an expensive device, and after all, almost qualitatively done.
All that INNOVV can make for users - give tool for upgrade/downgrade firmware and give NEW optimized fw. BTW i used back cam at forward side and forward cam at back side because the length of the wires at the cameras was insufficient.
If you think that my dissatisfaction with video quality is not justified, here is the video of the original quality. Not an "optimized" by YouTube. And it's not beautiful like the video on your announcements.
After buying, installing and viewing the quality of the picture, I now have to more carefully approach the purchase of such devices.
https://www.solidfiles.com/v/8Nwwqgwqyrng5
@ zerbino19, The DVR in luggage may has the small sealed off space, that is not easy to release heat. from below we can see if DVR is under seat, heat release will be easy.
By the way, my friend was forced to attach the radiator and fan from the battery side.
We received such photos your friend shared, he is skilled and made very cute install with fun.
Can you let me know what features you do need?
I was worried about overheating as well, but I found that this has not been a problem (I am in Australia). Have you emailed Rock (from Innovv), as he and the team were very helpful in trying to resolve my initial issues with the K1.
