Hi Rock,
I just received a replacement dvr 2 days ago after a month waiting, I fixed the dvr into my underseat and noticed that i can not get to change the view from the "preview or recording mode as described in the manual.
when the dvr is recording, the mode button is ineffective, hence the recording is only showing the front camera.
what should i do?
All buttons had been tested before shipping, pressed and it is reactive.
Can you try to press it at different location on top of the button and see if it works?
Hi Rock, Thanks for your response, I have tried different location and different angle on the button, it doesn't respond while the dvr is recording, of course the 'Mode' button is working while the dvr is not recording - the mode button works to change the setting.
The only problem i have is to change the channel to be able to track front and back recording, but it is the front camera that works at the moment.
I'm having the same issue. Every time I press the mode button I get a "bong" tone, but it does not change my recording mode. I am stuck in rear camera only mode. VERY frustrating...
Terry, did you end up getting yours fixed or did you just abandon the camera like so many others I've read on this site?
