When trying to set in a CAR ID, the manual says that it can hold up to 9 digits or letters, but initially I was only able to set in 3 digits. The manual is NOT clear on how to do this. I finally realized that the letters CAR ID are a part of those 9 letters or digits. This is NOT stated in the manual. The way to get all the letters or digits is to use the little back arrow at the bottom of the menu and delete the CAR ID letters. THEN you may enter the full 9 digits or letters.
What manual? I cannot find a manual. The "manual" they talk about is simply a restatement of the app prompts. It is laughable. Only its not funny.
About Car ID, 1. Press Mode button is to switch between rows, 2. Press << or >> button is to move left or right between letters. 3. Press OK button to confirm the selection. You can move cursor to ← and press OK button to delete Car ID. and move cursor to the word you like to select and press OK button to confirm the selection.
You can first delete Car ID, then select the letters one by one. After set all letters, Max. is 9 characters, press OK button, the menu will exist, and you check the set stamp.
