I did the same when mounting them as the clearance worked out better mounted sideways, had to change the full mounting set up on the front of the bike, a bit of a pain but....
I've also had both brackets (supplied) snap off at bends,would keep an eye on them, luckily had the cable zip tied so when camera fell it never hit ground or wheels....
Not been what I was expecting but runs ok.. is. Lens protectors which should supplied free are a must, my front one is demolished at the moment will need to order more.
Yes, the view only flips 180.
Thanks. I thought so :/
I'll have a look at re-mounting of just accept changing the view in software after I copy it to the computer
