Hello, I bought a replacement C5 for a broken one. I updated the firmware and it seems to behave normally but I cannot turn off the WiFi. When I press the green button it flashes and eventually reconnects. It never gives the 1 flash per second. Has there been a change? Thanks.
Sorry, I meant it never gives the flash that is slower than 1 per second.
hi,
When you use the mobile phone to connect the APP, can you see the WiFi of C5 on the WiFi list of your mobile phone?
If yes but you can not connect the APP, please forget the C5 network on your phone and then try again.
If there is no C5 wifi on your, please check again the C5 DVR, you can use a usb power supply to try again.
Thank you for your reply. I can connect the camera to the app no problem. My only problem is I want to turn OFF the WiFi. I should be able to press the WiFi button on the camera and the light should slowly flash green with the WiFi disconnected. Instead, when I press the WiFi button, it flashes green once a second and then reconnects.
I didn't have this problem on my old camera. Are there previous firmware versions available that I can try? Thank you.
You're welcome.
Our engineer tested the all frimwares of C5 but we found only V0.31 can turn off the wifi.
But we are concerned that this firmware version is too low to be compatible with the current APP, so we will re-edit the firmware.
Please use the current version for the time being.
Sorry for the inconvenience caused.
No problem. I'm glad it will be fixed because other than this small problem it has been a great camera.
@frankrizzo Thank you. The APP will pop up to remind you to update when we publish.
Hello - is there any update with this? If not, can you just give me the the old firmware and old app apk? Thanks.
hello, here is the firmware.
Please download it, then you can turn off the wifi function by pressing the button.
https://www.dropbox.com/s/pwtkepr8k53ufs3/C5.bin?dl=0
@innovv Thanks a lot - that seems to work great. :-)
@frankrizzo welcome!
