I'm having problems with the wifi connection to my phone. It connects then after a minute or so it disconnects. I'm guessing it's a phone issue, any tips on proper settings?
Followed the test instructions the other day and everything checked out. Switched from a 64 gig Samsung to a 32 gig Sandisk and it still kicks me off wifi after a few minutes. Also, I get an error message when trying to view the live feed and then the app closes. I can see the live video behind the error message before it shuts down.
Looks like default settings and permissions. I have also noticed if checking thumbnails to see if it's recording, it stops. I did this before leaving work the other day and missed a road rage video between a car and a van, too bad.
What Mobile phone do you have?
Follow up below procedure to do check,
1. Make DVR and mobile phone close like 20cm.
2. Remove SD card from DVR.
3. Turn on ignition, Green WiFi LED is flashing, Red Power button flashes quickly.
4. Connect to your mobile phone via WiFi to see if it works.
If Connected, Please change SD card.
I have an LG android phone.
It also does this sometimes, possibly wifi interference I've read in a few other posts?
The thumbnail picture review issue, Can you check if you have approved INNOVV C5 storage?
@ barclatheus
If you check the setting, or review the recordings, before exiting the APP, you need to enable the recording.
Anyway, App will be updated, no matter what reason to exit App, the camera system will automatically start recording.
