I have plugged the whole camera set-up together on my desk. I’ve tried on an iphone 7, iphone 6s and an older ipad but no device is detecting the C5. The green light is blinking slowly, indicating wifi is terminated, but pressing the wifi button (even for a few seconds) does nothing. i have reset the unit and an unformatted SD card is inserted (awaiting formatting once i connect to the app). please help
I had similar issues. It improved once I’d formatted the SD cards, but did this via the units as I couldn’t get the App to work
In fact I’m not impressed with App as even writing this has become a challenge
As screen freezes!
I’m not sure what you mean by ‘via the units’. Is there another way to format the card instead of through the app?
Copied from another post
1. SD card format,
If you are using 128GB SD card, please format it before the first recording by below way,
1). Format SD card from the setting on App.
2). Press red power button once to make it to solid red, and long press Green WiFi button for 8 seconds, you will see red power button flash once.
You need to format the SD card before use it --> Press red power button once to make it to solid red, and long press Green WiFi button for 8 seconds, you will see red power button flash once. Or -->Download SD card format software, and format the SD card to be FAT32 in your PC.
Please click this link for reference to format your SD card https://www.dropbox.com/home/Wix%20website/INNOVV%20C5/User%20Manual?preview=SDcard+format.mp4
I also have no wifi connection. Reformatted SD card via my macpro. Tried to use via app on my phone and my wifes higher spec phone but keeps coming back no wifi connection or possible incorrect password. Can anyone suggest a solution
