Hi, I’ve had to download new firmwear due to changing loop time. Now i have no red or green lights, the DVR appears compleatly dead. It looks as if no power is getting to it. So can’t try anything, Not even when connected to lap top. So any ideas out there.
Same problem, but I did not get a chance to download the new firmware after changing to the 10min loop time. Now not only will the unit not connect when on the bike as all I get is a solid green but no Wi-Fi coming from the unit it also wont connect to my PC and I get an error message on the PC saying the USB device has failed and is not recognized. I have formatted the SD on the PC and reinstalled it but the problem persists. I have tried the hard reset button on the unit but noting. Plugin into the USB wall power I get 1 red flash on the power light and then nothing again.
i have the same problem Blur, solid green light but will not connect, according to the unit its connected but to what i have no idea.....RESET does not do nothing, just goes back to solid green light....
Got a response regarding the issue, I’m posting it here first but won’t be able to try it for a day or so. Hope it works for you
Hi Nicholas,
Happy new year!
Nice to get your message and I am happy to help.
“Please click below link to download bin file to root of SD card, and insert SD card to camera system, power on camera system, you can see red button flashes quickly, you can refer the video from the drop box.
https://www.dropbox.com/sh/25p7at304vxwih0/AAAMK9YNRcbDx7hSHLq6jCDma?dl=0
After then you can connect your mobile phone to camera system.
Camera system wifi does not work with PC wifi connection.
Just try and keep us updated if have further question.
Have fun and enjoy, “
HI Blur, I emailed them and they gave a fast response on New Years day,
They told me to download a Bin file to the SD card, I also cant connect to the PC and no connection to the phone, this also happened when I change to loop to 10mins.. Anyway, I got the file on the card and inserted it to the DVR and sadly it made no difference...
Without the card I gat a constant green light but no connection
With the card I get a Red and Green on constant..
Im going for a ride tonight to see if it records while riding, i hope it records and then pop the card out if any incident happens... ill report back !!!!
Oh, Ive informed them that the file does not work but not had a reply, that was about 18hrs ago...
One more thing.... My reset but doesn't do anything, Its just not resetting....
Just an update, I tried you link Blur and put that on the SD card, no results.... Still no wifi....
Think im just going to send mine back to Amazon and get another make, clearly this one still in its test stages and problems are not 100% sorted, sad really..!!!! I'm more pi**ed of because Ive got strip the bike bown to remove it..... ((((((( Innovv!!! Look and read these!!!! ITS NOT GOOD!!! )))))
Latest response hope it works.
Our guys did further testing again, to be sure it works with 10 minute set up.
Please follow up below instruction to download bin file to SD card, and then insert SD card to camera system, power on camera system, you can see the red button is flashing.
https://www.dropbox.com/s/nnk936wcmq343aq/INNOVVC5.bin?dl=0
and you also can click below link to watch the video, you can see how the red button flashes when firmware update successfully.
https://www.dropbox.com/s/o1f3qc3edn67if4/Firmware%20update-02.mp4?dl=0
Keep us updated after checking,
Regards,
Rock Liu
Another update, I got it to work...Whaaaaaa Haaaaay..!!!!!! well for one ride anyway... GRRRRR
I got home and powered down, I then powered up to see if it would connect.. Guess what...? NO..
What i did find by mistake is if you press both buttons it will reconnect but this is no use if the unit is in a awkward place or under you seat....
To be fair to them they are in contact with me and are trying to sort it...
One more thing, the camera bracket broke, Ive seen stronger tin foil... bad design is that..!!
Had enough... Sending it back..!!
