This is just to show how to install the INNOVV C5 on BMW R 1200 GS 2016.
First of all, I chose where to install the camera system on my GS as follow.
Then, I prepared some accessories:
> Stainless steel bracket, black painted, to mount the lens
> Plexiglas plate to mount the DVR
At the end, I prepared a dedicate wiring, for the camera system, to avoid any interference with the wiring of the motorcycle. I used only GPS power connector of the motorcycle to control video recording, when the engine starts or stops.
Installation
I installed the on/off switch on the handlebars near the Start/Stop engine
I laid the wiring along the motorcycle frame
I connected the wires to the battery (red wire to the positive terminal and black wire to the negative terminal)
I installed recorder unit under the back seat
I installed the lens in front of the motorcycle
I installed the camera system without to change the original circuits and without holes in the motorcycle, but I took four hours to make the new wiring and to pass the wires into the motorcycle.
October 25, 2017 | Rossano – Italy
...hmm, interested setup. I have a K1600GTL. Because I have several other farkles installed, I was able to connect the wiring harness to my Neutrino Black Box.
And with the relay I realize galvanic separation between the circuits.
I need relay because BMW does not want any equipment (no BMW) connected with motorcycle circuits.
My motorcycle is still under warranty, so I do not want any problems in case of motorcycle failure.
The current of the relay is low, so BMW cannot tell me anything.
@Rossano, thank you for sharing, you are skilled. That is good reference for GS.
Why do you need relay? Does GPS connect to a switched power source?
