Hi, I am looking at getting a C5, can the WiFi be set to off/disabled on boot, meaning it is only enabled after the WiFi button is pressed?
When you turn on the motorcycle, the WiFi of the C5 will also be turned on.
However, if you don't want to use the WiFi feature, you can press the green WiFi button once and the WiFi will turn off.
Once more, the WiFi will be turned on again.
Is it possible to disable this functionality, it would be a pain to press the button every time to turn it off?
Yes, you need to press the button every time you start up to turn off the WiFi function.
