Sep 10, 2017
Devise Dead.
2 comments
Hi, I also have had problems with the devise locking up after changing the recording settings from the default 3 mins to 10 mins, after reinstalling the firmware then all is ok again but the last time it happened the devise turned off and will not turn back on, i have connected the USB and also checked the supply on the bike and is ok at 5 volts.
Has anyone else had a similar issue with the devise completely dead ?
I have emailed Quentina Qiu at Innovv and am waiting for a response.
Sep 11, 2017
There is a bug on video segment set to be 10 minutes.
Once set to 10 minutes, the camera will dead after SD card get fulfilled. there is no enough remain space on SD card.
You can set video clip to be 5 minutes, and we have been working on this bug.
Sep 11, 2017
Ok thanks Rock, if I can get the devise to turn on ill set to 5 mins, i have sent a video to Quentina showing the problem i have got with the devise, hopefully they will sort it soon.
New Posts
  • w-tbird
  • w-facebook
  • w-googleplus
