Hi received the C5 but got it on test before fitting after 30 minutes of running seemed to have frozen with flashing lights, pressed reset and boots up/powers on but lights flash now does nothing. Going to try charging via usb for a while but any thoughts ?
Hi Jamie,
The K1 has two LED lights, one is WiFi, green color, other is red for power.
1. Green LED is flashing, WiFi from camera system is available to connect.
2. Green LED is solid green, no flashing, WiFi from camera system connected to mobile phone via App.
3. Red LED is flashing, Camera system is recording.
4. Red LED is solid red, no flashing, Recording stop.
5. If without SD card, Red LED is quick flashing.
Can you let me know if Red LED is flashing?
Did you connect camera through WiFi/App?
Regards,
You didn't mention how the camera was powered during the test run. Did you connect it to the motorcycle battery or using the internal battery? I had an issue connecting to one C5 camera, but it appeared to be a bad SD card. I switched it, reset the recorder and switched it on. Both C% camera cameras are working, although it is tricky to snyc the videos as they start recording at different times. I have to tag and align the same time on the time stamp to sync front with rear camera shots.
I own and installed two C5 cameras. My comments are for the C5 camera.
Has seen your other post! Great installation!
