Dec 15, 2017
2015 GS1200 connection
2 comments
Hi. Ive come to the point of connecting the yellow wire to a switched circuit. How? Where can I physically connect it? I cant find any electrical connections anywhere. Obviously I appear to be a bit so simple explanation required please.
Dec 15, 2017
You have to splice it into a wire that comes on with the ignition like your tail light or head light.
You can connect with the KL15/ Acc ignition or tail light or head light will be OK.
New Posts
  • The camera doesn't connect, and the red light stays on, so I have no idea if it has recorded anything, the forum is no help, waste of money!
  • Hello, I bought a replacement C5 for a broken one. I updated the firmware and it seems to behave normally but I cannot turn off the WiFi. When I press the green button it flashes and eventually reconnects. It never gives the 1 flash per second. Has there been a change? Thanks.
  • w-tbird
  • w-facebook
  • w-googleplus
