I would like to add a 3-way switch to my installation.
- Normal (automatic, normal use)
- Always off (for "spirited riding")
- Always on (to access the camera via wifi with the ignition off)
I am pretty sure that I have seen such a clever wiring scheme on this forum, but I am not able to find it?
Hi,Adv, we are happy to be helpful, yes, you can make a special switch if possible, good luck and wish you enjoy more funs with INNOVV.
Hi Adv, you can make a 3-switch, one switch connect to the ACC for normal use. One switch to NC for "Always off". One switch to the postive pole of the battery for "Always on", but when this switch on, the DVR will keep on recording and drain the battery, there is really no good way to get wifi when DVR is not working. If you still have questions, would you please contact cs@innovv.com for more assistance?
This is not what I want, please read again. I want to be able to switch between these three modes.
Hi, my friend, if you want to make it always off, please connect the black& yellow wire to the negative pole of the battery, and red wire to the postive pole, but if you want to make it always on, you can connect the yellow&red wire to the postive pole and black wire to the negative pole, it will drain the motorcycle's battery if you keep the dvr always on. We really suggest that you can connect the INNOVV in the normal way.
