FIRMWARE, MANUALS & APP
K6
K6 firmware:
IK6.20230726.V1.0.01
Changelog:
How to update firmware:
1. Copy the firmware (INNOVVK6.bin) to the root of the TF card. (Please use 8 to 32GB TF cards and the TF cards should be formatted into FAT32 in advance.)
2. Insert the TF card into the camera and turn it on, you can see the red light and green light blinking alternately, please wait about 50 seconds until the lights are off.
Please do not power off and operate the K6 while it is updating. After the successful upgrade, the K6 will automatically boot up and the red light will solid on. The firmware will be deleted once updating is finished.
(*Important: the power should not be cut off during the firmware update.)
K6 manual:
Click here for K6 manual.
INNOVV App
INNOVV App
Download INNOVV App from App Store
Download INNOVV App from Play Store
INNOVV K5 4K Dashcam
H5
H5 firmware:
H5.C.20230213.V1.1.02
Changelog:
Fix some bugs we found.​
1. Download the firmware(INNOVV H5.BRN ) and copy it to the root directory of the TF card.
2. Insert the TF card into the camera and turn it on, you can see the red light and green light blinking alternately.
Please wait for about 100 seconds, the update is completed when the power and the lights go off automatically.
( Caution: Please make sure that the battery is sufficient before inserting the TF card.The power can not be cut off when the red light and green light flashing alternately; The firmware will be deleted once updating is finished).
H5 manual:
      Click here for H5 manual.
Download INNOVV H5 App from App Store and Play Store
Video tutorial
H5 APP INSTALLATION & PERMISSION IOS
K5
K5 firmware:
V1.1.12 update 20210827 (With Default 5.8 GHz Wi-Fi)
V1.1.12 update 20210827 (With Default 2.4 GHz Wi-Fi)
Changelog:
​1. Fix the bug that causes the system to crash when turning it off.
1.  Click the above link to download the latest firmware named K5.bin to your computer.
2.  Copy the K5.bin file to an SD card. The file name must be the original name and other names could not work, such as
K5(1).bin or K5(2).bin.
3.  Insert the Micro SD card into your INNOVV DVR.
4.  Power on your INNOVV motorcycle camera system and the firmware will be automatically updated with the green light
flashing erratically.
Once update is successful the blue light will be flashing on a regular basis appx once a second. If for any reason the update
was not successful, please repeat the update.
K5 manual:
      Click here for K5 manual.
INNOVV App
INNOVV App
Video tutorial
K3
K3 firmware:
V1.1.15 update 20220521
Changelog:
1. Fix the bug that could cause files name errors.
2. Alter the file folder name to INNOVVK3
1.  Click the above link to download the latest firmware named K3.bin to your computer.
2.  Copy the K3.bin file to an SD card which shall be in FAT32 format. The file name must be the original name and other
names could not work, such as K3(1).bin or K3(2).bin.
4.  Power on your INNOVV camera system and the firmware will be automatically updated with the green light flashing
erratically.
K3 manual:
      Click here for K3 manual.
INNOVV App
INNOVV App
Video tutorial
ThirdEYE:
ThirdEYE manual:
      Click here for ThirdEYE manual.
ThirdEYE
k2
K2 firmware:
V0.70 update 20200513
Changelog:
1.  Add the function of turning the lens flip 180°.
1.  Click the above link to download the latest firmware named K2.bin to your computer.
2.  Copy the K2.bin file to an SD card which shall be in FAT32 format. The file name must be the original name and other
names could not work, such as K2(1).bin or K2(2).bin.
4.  Power on your INNOVV camera system and the firmware will be automatically updated with the red light flashing erratically.
K2 manual:
      Click here for K2 manual.
INNOVV App
INNOVV App
Video tutorial
INNOVV C5 MotoCam
C5
C5 firmware:
V0.47 update 20210120
Changelog:
1.  Click the above link to download the latest firmware named INNOVVC5.bin to your computer.
2.  Copy the INNOVVC5.bin file to an SD card which shall be in FAT32 format. The file name must be the original name and
other names could not work, such as C5(1).bin or C5(2).bin.
C5 manual:
      Click here for C5 manual.
INNOVV App
INNOVV App
Video tutorial
