Format 64GB or 128GB sd card to FAT32
INNOVV C5 & K2 only support 64GB or 128GB SD card in FAT32 format.
Windows can not format more than 32GB in Fat32.
EaseUS partition tool is the best FAT32 format tool to format SD card to FAT32.
Note: Formatting will delete all your data, please be sure to backup all your files before starting the job.
Partition Master Software Download and Install
Click Blow Icon to download Partition Master and follow the instruction to install in on your PC.
Follow up below instruction to format SD card to FAT32.
Step 1. Connect SD card or USB flash drive to your computer, launch EaseUS partition tool, right-click the card you want to format and choose "Format partition".
Step 2. A mini window pops out, on which you can edit the partition label and choose a file system such as FAT/FAT32, NTFS, EXT2/EXT3.
Step 3. Click "Apply" to confirm to format your 64GB SD card/USB flash drive to FAT32 with ease.
More details, you can click below link, https://www.easeus.com/partition-master/format-64gb-sd-card-to-fat32.html
